Gotcha! Good to hear that things are running speedily again on token data. It just can be tricky on reduced speeds since speeds (reduced or not) can and will fluctuate. I usually see speeds fluctuate by 2-3 Mbps, but I've also seen changes of over 10Mbps. So when your speeds are reduced and have already a small range to work in, seems to me to be a challenge to consistently stay on the higher end. Especially if you have multple devices on the network; imagine splitting up 2 Mbps across 3+ devices.
Its been running well since Monday, but its just now(or within the last hour) started the slowness again, my download speed on the testing site went from 322kBs to 29kBs!
I entered the FAP condition yesterday though, and before then it was running fast as the test shows, so I definately think this is something on the outside of my set up. But never know of course!
Glad I'll have my full data back in the next day or two, but it was doing this crazy slow mess even when I still had data during the bonus zone time(and of course, during the bonus time!). Would this indicate an overload of people in the area? The only internet running devices right now are the Dish Hopper that shouldnt be doing anything, and that aforementioned printer, so I dont think I have a data leech hiding anywhere, and since it worked fine while I had the data token, it must not be anything to do with my modem or dish itself.
Hopefully it'll resolve itself soon though!
Edit: Just to note, on the last test that showed 29kB/s, I only did a 1MB download since the slowness hit, noticed that a forum was loading like it just woke up in 1994, gonna do some 3MB ones. Also nothing of note happened before it went back to the crazy slow. I was watching youtube videos in low quality this morning, but I wasnt at the computer or any internet device when the slowdown began. Also my state code is 24.1.1 Download Throttled
- Liz5 years agoModerator
- Danny895 years agoJunior
Not sure when it started running correctly, but its been running well since yesterday, and my data turns over at midnight so that should work fine!
At this point with how its been going and what testing has been done, is it safe to assume that its not an issue with my equipment, or an issue with the entire Hughes system(communications with the satellite or something wrong at the ground station), and just that theres a heavy overload going on at certain times?
Its absolutely brutal, but if there is an overload, thats all there is to it- maratsade5 years agoDistinguished Professor IV
From what Liz says, it seems the issue is heavy traffic on the network. This will be very noticeable to you if you're in FAP.
- 11 months ago
- 11 months ago
