prsmart
9 years agoSophomore
System light blinking
We had a close lightning strike yesterday evening, and since then my HT1100 modem ONLY has the system light blinking. No other lights are on. Any assistance would be appreciated.
prsmart
8 years agoSophomore
I did not return the old modem because this message said it was not required. Now, I've received a message from Hughes saying they've not received the modem and will be billing my account if not received.
8 years agoModerator
Thanks for the heads up, prsmart! I've manually received the modem in our system so it doesn't require any further action from you.
