System went down for about half hour today
Yeah, that's the NOR gateway if I am not mistaken, looking at the weather maps it looks like there was possibly some bad weather in that region today around that time. After a short while if the modem can't get connection to the gateway it will give up on transmitting data and wait for the recieve data to come back before it starts transmitting again.
It's also possible there was a gateway issue, or one really strange modem issue... As far as software updates go, any time you reboot these modems in any way, they will go through a software update.
NOR = North Platte, NE
When today did it go down? That is abnormal behavior, however, there appears to have been some inclimate weather in the region for your gateway if you are Beam 81 J2
- cybercycle19 years agoJunior
Thanks for the response, Corrosive. It was about 3:00 p.m. Central time today. I've been on HN for over a decade and thought this behavior was unusual. System is still up, so maybe you are right about an atmospheric issue being the cause. I'm on Gateway 12 of Beam 81.
NOR = North Platte, NE- cybercycle19 years agoJunior
C0RR0SIVE wrote:Yeah, that's the NOR gateway if I am not mistaken, looking at the weather maps it looks like there was possibly some bad weather in that region today around that time. After a short while if the modem can't get connection to the gateway it will give up on transmitting data and wait for the recieve data to come back before it starts transmitting again.
NOR = North Platte, NEI believe you nailed it! Thanks for the explanation and research on this issue...I really appreciate it.
- 4 months ago
