System will not boot
- 7 years agoOver 12 years and HughesNet has taken care of me again. Thanks Amanda.
Only two lights are lit, power and wireless.
Try disconnecting the power and then the coax. Let it rest for a few. Reconnect coax and then the power. Maybe it will boot. This has worked many so many times for me I named this procedure the coax dance.
- dzfire7 years agoSophomore
Tried the disconnect last night ;) As a side note, I've been using HughesNet since the days of DirecWay out here and have been happy with it for the most part. Just gotta get back up and running so I can start work taody. :D
- GW7 years agoAdvanced Tutor
The new wifi modem doesn't get too hot but heat is another thing that used to shut me down. The 9000 was like a furnace. Sorry but that's about all I have for you. I hope Amanda can give you some help. No internet is very frustrating when there's work to do.
- Amanda7 years agoModerator
Hmm, alright. So I cannot communicate with your modem because it is not transmitting out. If you try to access http://systemcontrolcenter.com does that redirect you to the control center page? To go forward I really need to get the state code from the modem, so the first thing we need to do is get to the modem's home page. ~A
- 2 months ago
- 3 months ago
