Tech Realigned Satellite Dish, Still Experiencing Problems In FAP
Managed to get this just after this post:
:::.. Download Speed Test Result Details ..:::
Download Connection Speed:: 81 kbps or 0.1 Mbps
Download Speed Test Size:: 480 kB or 491520 bytes
Download Binary File Transfer Speed:: 10 kB/s
Tested At:: https://TestMy.net
Validation:: https://testmy.net/db/UjuK9hidk
TiP Measurement Summary:: Min 0.02 Mbps | Middle Avg 0.12 Mbps | Max 0.42 Mbps | 162% Variance
Client Stats:: https://testmy.net/compID/36927797294697
Test Time:: 2023-10-18 11:22:59 Local Time
Client Location:: Efland, NC US https://testmy.net/city/efland_nc
Target:: Dallas, TX https://dallas.testmy.net
Client Host:: Hughes Network Systems https://testmy.net/hoststats/hughes_network_syste
Compare:: 100% < host avg, 99% < city avg, 100% < country avg, 100% < world index
1MB Download in 2 Minutes - 1GB Download in ~29 Hours
This test of exactly 0.47 MB took 49.086 seconds to complete
User Agent:: Mozilla/5.0 Windows NT 10.0; Win64; x64; rv:109.0 Gecko/20100101 Firefox/118.0 [!]
hellovolchitsa,
Thank you for following up! I'm glad the modem arrived promptly, and was able to be fully set up. Is this the first time you've had issues with FAP following installation of the new modem?
Remy
- hellovolchitsa3 years agoSophomore
Yesterday it was also bad but it was a bit cloudy and I was dealing with stuff, so I wasn't constantly at the computer to really keep messing with it until later. It was also a problem then; Monday it worked fine (as well as Sunday night after the hour long phone call to install it manually.) So Tuesday it was messed up, Wednesday I had time to come in and post. It's back to barely working at all and hasn't since Tuesday morning. Even when I entered Bonus Zone last night, it never sped up, even if I had data - always was barely loading anything. I did restart the modem, the computer, change browsers, etc. the works all over again. No change to how it is working.
It also sometime Monday dropped the '5g' connection and now only the 2g shows up. I changed nothing. It kicked me off/went down, and when it came back up, 5g option was gone and only 2g was available.- GabeU3 years agoDistinguished Professor IV
Just for the sake of troubleshooting, do you have a device that you can connect directly to the modem via ethernet cable to see how it tests in comparison to the WiFi connected devices? I don't know that WiFi is the problem, but again, just for the sake of troubleshooting.
If you already mentioned that you tried something like this and I missed it, please disregard this reply.
I just went to test it with my laptop because this is a good suggestion and the problem persists even when connected with the cable that came with the new modem. It's the same laggy internet that tests 0.01. (I couldn't get it to load this for I could post from it or share directly, but it was similar to the speed test above)
