David_78933
5 years agoSophomore
Transmit / Uplink Problem
My Hughes system has started having transmit problems (state code 12.1.9) today. I rebooted the HT2000W modem once, when we lost internet access all together, and it helped to clear the problem for ab...
David,
Remy
Weather issues at the gateway can affect your signal too. If there's a problem at the gateway, it's usually temporary. The mods here can probably check your system remotely and see what's going on. Give them some time to respond.
