Transmit / Uplink Problem
David,
Remy
Weather issues at the gateway can affect your signal too. If there's a problem at the gateway, it's usually temporary. The mods here can probably check your system remotely and see what's going on. Give them some time to respond.
Best to let the mods check to see whether there's an issue at your location or something going on at the ground station. They usually respond within a day or two, but if you're in a hurry, you can always call the customer service number (24/7) or use the chat.
David_78933 wrote:
Thanks. I should have mentioned that there is no weather in Wyoming at the gateway, either.
