David_78933
6 years agoSophomore
Transmit / Uplink Problem
My Hughes system has started having transmit problems (state code 12.1.9) today. I rebooted the HT2000W modem once, when we lost internet access all together, and it helped to clear the problem for ab...
David,
Remy
David_78933
Thanks. I should have mentioned that there is no weather in Wyoming at the gateway, either.
Best to let the mods check to see whether there's an issue at your location or something going on at the ground station. They usually respond within a day or two, but if you're in a hurry, you can always call the customer service number (24/7) or use the chat.
