Transmit / Uplink Problem
David,
Remy
- Remy6 years agoModerator
David,
Thank you for posting! I was able to look into your account and keep up with the errors you've been keeping track of. The normal culprit of these issues is either a Gateway issue, as maratsade and Gabe were discussing, or a general alignment issue. I looked into both, and neither seem to be an issue. In that case, the most likely issue is the equipment malfunctioning, and I've seen an influx of errors within the modem itself. I'm going to be sending you a new modem, with the fees waived. When you receive the box, it'll have a prepaid shipping label meant for return of the previous equipment. Please let us know if this new equipment resolves your issues!
Remy
- David_789336 years agoSophomoreThanks, Remy! Any idea how long the new modem will take to get here? And will there be instructions with the new modem, or is plug & play?
David,
It normally takes between 1-3 days from what I've experienced, so expect it by Thursday! There should be instructions on how to get the modem up and going as well.
Remy
