Transmit / Uplink Problem
David,
Remy
David,
Thank you for posting! I was able to look into your account and keep up with the errors you've been keeping track of. The normal culprit of these issues is either a Gateway issue, as maratsade and Gabe were discussing, or a general alignment issue. I looked into both, and neither seem to be an issue. In that case, the most likely issue is the equipment malfunctioning, and I've seen an influx of errors within the modem itself. I'm going to be sending you a new modem, with the fees waived. When you receive the box, it'll have a prepaid shipping label meant for return of the previous equipment. Please let us know if this new equipment resolves your issues!
Remy
- Remy6 years agoModerator
David,
It normally takes between 1-3 days from what I've experienced, so expect it by Thursday! There should be instructions on how to get the modem up and going as well.
Remy
- David_789336 years agoSophomoreThanks, Remy.
- David_789336 years agoSophomoreRemy, overnight last night my system resumed "normal" operation. There have been no system state codes today. Upload speeds are consistently in the 1.8-2.2 Mbps range, with an occasional one at 0.2. My question -- Should I go ahead and replace the modem now (due here today, per UPS), or wait until it acts up again so I can be sure the modem is in fact the real issue?
David,
I would recommend trying out the new modem! It'll eliminate the old modem as a possibility, and hopefully end any experimenting we'd have to do with you.
Remy
