Two Months of Slow Speed, Even After Gen 5 Upgrade
Good morning Colby,
Engineering has an update planned for your gateway tonight which should address the intermittent connectivity you're seeing. To be safe, please power cycle the HughesNet modem before you use the internet tomorrow. To power cycle the modem, unplug the power cable from its power brick and replug after 30 seconds. Allow some time for the modem to recover before attempting to browse. Please let me know if the disconnects go away after this.
I'll tag the reps. There may be a reason that you were left on the ES17 satellite. Hopefully they can give you some answers.
The reps are on M-F from approximately 8AM to 5PM EST, but it may take them a day or two to reply.
Thanks! I hope to hear from someone soon.
- Liz8 years agoModerator
Hi Colby,
I'm glad you found the community, thank you for posting. For your beam, we've deployed code to help address speed concerns, but that was at the beginning of the month. I'll escalate to our engineers here at corporate for their insight. In the meantime, please run at least 3 speed tests at speedtest.net spaced 5 minutes apart while directly connected to the HughesNet modem. Since you have the HT2000w now, please also disable the wifi there so that there isn't additional wifi traffic while you're running speed tests.
- Colby8 years agoSophomore
Ok, Thank you Liz. I hope to get this resolved eventually. I haven't noticed much of a difference since the beginning of the month. The last speed test I ran on (testmy.net) yesterday was 500 kbps download. But this evening, the connection is especially slow.
Good morning Colby,
The engineer hasn't found anything out of the ordinary with your beam, so I've requested for his examination of your site in particular. Once I have any news or additional questions, I'll let you know.
