Wifi going down
Assuming you are connecting wirelessly, you would first open a browser, put your mouse in the browsers address bar and click the mouse then enter the numbers 192.168.1.1
Don't forget to enter the decimal points where shown.
This will bring up your Routers log in page.
If you can't reach the Router in this manner it is indicative of a wireless problem between your computer and your Router or a Router configuration problem.
Next you would do the same but instead enter 192.168.0.1
If the Modems SCC page opens this means you have connectivity through the Router and into the Modem.
While there you should be able to see any listed error codes and you should also be able to see your remaining data allowance. The latter means your Modem is connected to the Hughes Gateway and you should then also have access to the internet.
As to snips, open the snipping tool and take the desired screenshot and then save it to your desktop.
Once save you can add it to your community post by clicking the camera icon just above your post with the word Photos next to it, navigate to where you saved the snip and then hit the upload button and then hit the reply button to post your reply.
Don't enter in search box, type in the address bar and then hit "Enter" key. Make sure it is 192.168.1.1 not 192.168.11
- 11 years ago
