Wireless Router problem??
It's probable that the performance of the laptop, at least when it comes to things like opening and running basic programs and such, is faster due to it being more integrated. Feed it something more intensive and it will most likely fall behind the desktop, and quickly.
If memory serves right Gabe, the FX-6100 is a good bit slower than an i3 @ 1.9Ghz (I assume an i3 3227U?). Which would explain why the one with a lower amount of RAM feels the same, if not faster. Regardless, I can almost promise ya, if you upped your RAM, then prefetch would be a happy annoyance.
