Playon having issues with slow download speed?
I have tried to find a solution to actually be able to use our HNS service for something other than just emial and very light browzing (no videos). It was suggested here that Playon could be a solution - to download during the early morning so as to have better performance due to less traffic and to not affect our daytime data cap. I am now working with Playon Tech Support (who have been great) to understand why that is hit and miss. We are able to download maybe one or two shows and then due to stalls and buffering the recording stops. This happens to at least 50 percent of the attempts. Sometimes we have to try several days to download a single one hour show. Meanwhile, each attempt takes away data from our allotment. This is all being done after 2am and before 8am. Ugh.
Anyone here have any advise or experience with this?
Thanks
When you say "We are able to download maybe one or two shows and then due to stalls and buffering the recording stops" you mean that the downloading stops, right? Recording happens in the cloud, bypassing your system completely.
POC is sensitive to congestion, so if there is congestion at the time when you try to download, the downloads will slow down or will stop. Unfortunately congestion can pop up at any time.
- spydermikeSophomore
Hi maratsade, what I mean is that if I queue three 1 hour shows to record between 2:15am and 7:55am, the forst two shows record fine but the third records only 2 minute of frozen frame and then stops. I get a message that my video has recorded.
Playon is researching this. The same effect happens during peak times like right now when I just tried it for them.
I am not usingPOC. I have the app on a dedicated Win10 Laptop.
Gotcha.
So you have PlayOn Desktop, or do they make a PlayOn Cloud app for PC? I used to have the PlayOn Desktop app and it was awful.
I then tried to just queue the one show for the next night, and same thing again, then again the next night.
- BobNBendSpectator
See my post on PlayOn home made today. I did not find this thread before posting it, but the observations there may be of interest.
RFB
Just got Starlink...initial test show min 120 to 220Mbps down, 18Mbps up and 18ms latency. My need for Playon as a crutch is over.
- MarkJFineProfessor
Thought half their constellation burned up in the last solar flare. Interesting.
Not even close...about 2000 satellites up there now I think. I think you are referring to a single launch of about 50 satellites that went up when the flare hit and some /most of those were affected before they were positioned. The service is working fine as far as we can tell. We are getting over 100 times better speed not to mention the much improved latency. The way it should be.
Oh, and I installed the system in about 10 minutes as the antenna assembly self aligns.
Knew the dish 'electronically steered' itself. I would think it almost had to given the elliptical orbit.
