Problems using cell phones over WiFi
Hello Rebyroo, cell over WiFi generally will not work well on satellite due to the high latency (ping). There is no remedy for the latency because the satellite is so far up in space.
1. Making calls over wifi via satellite Internet in order to supplement the mobile signal is not recommended nor is it supported. As I understand it, this is true for all satellite Internet due to the latency. Edit: Don't confuse phone calling extenders over wifi with the VOIP system HughesNet has in place. It operates on a completely different technology.
2. There is nothing in the HughesNet system that radiates at a power or frequency that will disrupt or interfere with your mobile phone's ability to make or receive calls. Pretty sure whatever is being experienced is a factor of the phone's proximity to available cell towers.
- 10 years ago
