tvignoe's avatar
tvignoe
Not applicable
10 years ago
Solved
  • As Corrosive mentioned the Verizon extender is not going to work very well if at all due to the latency inherent to a satellite connection.
    No matter what you do, your signal has to travel 22.300 miles up to the satellite then relayed back down to the ground at your Gateway location ... the return "data" has to again follow the same path.
    The speed of light applies here and about 580 ms latency is about the best you can expect.
