Speed and Plans
Speed and Plans
Is there an improvement in speed with higher-tier capacity plans?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Speed and Plans
@BooBoo
No.  The only difference between plans is how much high speed data you get before you are subject to the Fair Access Policy (throttled).  The offered speed for all Gen5 plans is the same.
Actual speed can vary due to system load, but upgrading to a larger plan won't improve the non throttled speed, nor the throttled speed, for that matter.
3 REPLIES 3
Re: Speed and Plans
@BooBoo
Re: Speed and Plans
Thanks for the quick response.
Re: Speed and Plans
@BooBoo
You're very welcome.  Smiley Happy
