The printer sees the 2.4 network but will not connect. I've entered the password correctly and also tried WPS. What do I do now?
Solved! Go to Solution.
Your printer may not support the wireless security cipher the HT2000w uses by default...
1: Visit http://systemcontrolcenter.com or http://192.168.0.1
2: Click Wifi-Setting on the left
3: Enter the password to access your wifi settings, by default it is admin
4: On the 2.4Ghz tab change the WPA Mode to WPA/WPA2, your cipher suite should change to TKIP+AES
5: Try reconnecting the printer, using the password that is displayed in the password field on that section.
Thanks Corrosive!
Thanks for this - I had this problem as well and this took care of it.
Thanks so much for this post!! We struggled for 2 days with this issue. We used this and Viola!!! We are printing!!!
