Solved! Go to Solution.
Hello @coogen,
Thank you for contacting us. I am sorry to hear you are experiencing issues getting your Nest product set up on our service. I would try toggling the UPNP feature to see if that makes a difference. You can find instructions here https://community.hughesnet.com/t5/Tech-Support/Resolution-for-Connecting-to-Certain-Websites-Xbox-C.... Please let me know if this helps.
-Damian
Have you tried contacting the company? https://nest.com/support/contact-us/
Edit: The issue may be related to IPv6. Hopefully a mod or another suscriber here will tell you how to enable/fix that with HN.
To try maratsade's suggestion regarding the IPv6, go to this modem page, use admin as the password, click on Advanced Setup, then IPv6. Uncheck the IPv6 - automatic box, then click Save Settings. This should disable the IPv6.
You may need to reboot or clear the thermostat's cache to have it purge the IPv6 address it has stored, though I don't know if this is necessary, nor how it's done if it is, as I'm not at all familiar with Nest thermostats.
Hope this helps.
According to this,
"If you’re trying to connect a Google Nest Protect, make sure your router supports IPv6. Your Nest Protect uses an IPv6 address to communicate and set up connections with other Nest Protects."
@maratsade wrote:According to this,
Ah. Well, in that case, don't turn it off.
Hello @coogen,
-Damian
Everything I've been reading (Edit: online, from people using NP) about your issue seems to indicate it's related to IPv6. See this post for how to set up IPv6:
https://community.hughesnet.com/t5/Tech-Support/Setting-up-Ivp6/m-p/105151/highlight/true#M71721
@coogen wrote:
So, I was setting this up at my Mom's on Hughes Net. Talked with Nest. They were no help. Never got it working.
Took it home with me, added it to my AT&T ISP and voila - worked like a charm. It's definitely a Hughes Net problem.
The only router settings (which is about the most limited web interface I've ever seen) that mention IPv6 has a check box for "automatic". Didn't work in either checked or unchecked toggles.
