jzman1
7 years agoNew Poster
Plan
I was introduced to Hughes via Direct TV. I sighed up for 20g, but got 50g. If I change to 20g when will I see a difference in the bill?
Hi jzman1,
Thanks for posting and welcome to the community! I pulled up your account just to confirm that you're on the 50 GB plan, and you are. If you were to switch to the 20 GB plan, then yes, you would pay less on your monthly bill.
You can change plans online in the Support Center by mousing over Shop/Upgrade at the top, then clicking Plans & Pricing. There you should see the available plans and prices in your area to which you can switch.
Hope that helps!
