Turkeylady3
5 years agoNew Poster
Big mistake
I switched from att inverse because I only had speed of 3 And Hughes has 25. Hughes is many times slower connecting downloading buffers all the time. As far as usuage . I rarely went over 20 with a...
If you're looking for help with a speed issue, please first read these instructions for speed testing, then run a few tests, then start a new topic in Tech Support, which you can do here, and post your testmy.net "My Results" page URL so that the test results can be viewed.
With this said, streaming right now can be problematic due to a combination of the high latency inherent to geostationary satellite internet and system congestion, which is being caused by much higher than normal system load as a result of the pandemic. Still, a couple of things you can try are reducing the resolution of the stream, whether locally, using the app or program, or at the website of the service, and turning off, or snoozing, the Video Data Saver.
