dclorentz1
5 years agoNew Member
Bill increased
There internet service not such a problem as the bill is the issue and for the last yr or so its been horrible. Taken out automatically and i never know the amount of what it to be cause it changes. ...
The reps here can look into your billing issues if you would like them to, but it's not clear from your post if you're asking for help or just venting. If you'd like the reps to look into this, you may want to describe what the issue is, and if you have case numbers from your calls, it would help if you provided one or more.
