Stasia68
3 years agoNew Member
Booster no help told to return for refubd
I bought the booster in attempt to help poor signal. Within a day I realized it didn't change anything. I was toldto return itsnd tgey woukd apply credit to my account.this has not happened. For it ...
3 years agoDistinguished Professor IV
Though a weak WiFi signal can cause extra data usage because of dropped packets, it's highly unlikely that it would use so much as to exhaust your data in three days. It's much more likely that something on your network is using it.
You can see the devices that use your network, including those that are currently disconnected, at the following modem page, which may help in narrowing down where your data is going.
http://192.168.0.1/limited.html#!/general/conn_dev_info
Streaming tends to be the biggest data user, but automatic updates and cloud connections on devices can be big data users as well. A connected satellite TV receiver, especially those from DirecTV, can also chew through data.
