Computer Identifies me and tells me 20 minutes to talk to a disconnect tech,then hangs up?
Hi Steve,
You're welcome!
In February when you initially called to cancel, that call got disconnected so the cancellation request was not completed; it was completed on your March call.
Hi Liz, yes it is 513?
Good morning Steve,
Thank you for the confirmation. Your account will terminate at the end of your billing cycle on April 4. THEN the return kit will be mailed to you so you can return your equipment. So once April 4 hits, it may take 3-5 business days for the return kit to arrive, as indicated on your cancellation call.
I hope this clears things up for you!
- steve772656 years agoNew Poster
Thank you Liz, That does clear it up. Does this mean I have to pay for the service till then as well? (even though I have not used it and was told a month ago this was done? I assume you can verify when I unplugged it)
- Liz6 years agoModerator
Hi Steve,
You're welcome!
Thank you very much for your efforts, It really helps an ole fart on a fixed income
