JR1981
4 years agoNew Member
Curious about usage
I switched to another internet 2 months ago and cut the wire on my Hughes Net dish, yet when I go on the app it says I have used all my date. How is this possible? Something smells fishy and this is ...
If you 'cut the wire' then the modem's not connected. If it's not connected, it can't update the system. So if you used all your data 2 months ago it hasn't changed.
MarkJFine
4 years agoProfessor
