CWM030
5 years agoSophomore
Data Alotment question
I have a question about my data alotment: Does my data refill on the 13th of every month or does it refill on a different day? Right now I am past my 20 days of relaxed data and I am down to ...
CWM030
I try not to.. But with my pc hardwired in, 2 phones, and Google Home I might use a almost gig a day.
MarkJFine
5 years agoProfessor
There's a bonus period between 2am and 8am where you should have an extra 50GB for the month. If you can tell your devices not to auto-update, then manually do it before 8am, you can significantly drop your anytime usage.
