Data not resetting
I must say, that does look odd. It appears that you have the 30GB data plan and that your data resets on the 12th of each month. Why the graph is not starting out at the 35GB level, like the three pictures from the previous month, is quite weird.
It looks like the graph is at the 16GB level, which is the next one higher than the 15.1GB you had remaining. It should start at the 35GB level, like the previous month.
What are your System Control Center and Hughesnet Usage Meter showing for your data amounts? Can you take a snapshot of those?
Edit: You posted a reply just before I posted this reply. If your thread was only for reference and the problem is already known and being worked on by the Hughesnet reps, disregard my post.
- Workdawg8 years agoFreshman
Is this the usage snapshot you were asking for?
It is, but I realized afterward that, without context, it really wouldn't establish anything other than what data you had left since the reset (that apparently didn't happen). The pictures you already provided actually show that something is not right.
I hope that this is rectified quickly for you.
- mandafayeee8 years agoNew Poster
I'm having this SAME issue and it's now been a couple months. It's claiming that I'm using 20 gigs within 5 days too! That isn't even possible when the wifi is only connected to 2 iPhones and hasn't been used for tv or a laptop in months.
I live in a 26 foot travel trailer with a secured network and haven't used our service for anything other than the phones. I've checked our cellular data usage compared to my Hughes as well and it makes no sense. I've been watching our Activity Monitor all day and we reset our phones data tracking as well. I've pulled up a bunch of websites, likely more today than ever in a day and the true uploads/downloads aren't reflected on Hughes. Also, going through account history, there's absolutely no way in HECK I have ever used uploads outside of the hundreds in MB scope and there are multiple days claiming I've uploaded gigs while we're not even here or asleep. Checked devices and it's only mine attached.
Our first month had terrible connectivity issues that we called on numerous occassions about, but we still ended the month with nearly half our gigs left and we were actually binge watching Netflix, streaming music and browsing constantly! This is ridiculous. I hate that we can only see the most basic info as possible on the meter and only goes back so far. I've been testing data tracking all day and it hasn't moved at all. Something has to be wrong.
Did you figure out anything with your account?
"I live in a 26 foot travel trailer with a secured network and haven't used our service for anything other than the phones"
mandafayeee, may I ask where the dish is mounted? Reason I ask is if it to the trailer then any slight movement can cause alignment to be off thus causing lost packets, retransmits and such, which can result in higher usage.
Did this ever get resolved and if so, can I ask what Hughes determined? Myself and about a grip of other customers are having this same issue between July - August.
