email problem
I can get to my inbox, but that is all. I can't open any email, all I get is "hughesnet isn't responding. Sometimes it will say 'due to long running script' but most of the time it's just 'hughesnet isn't responding'.
I have adblocker, IE 11. No email client.
when I switch to html version, I can actually open an email. But when I try to reply or start a new email, I get a 'can't display website' in the box where I'd type the text. I can enter the recipients address, and subject however.
Far as I can tell, all other browsing seems to be ok.
This pretty much came up since Monday morning.
Any ideas? Thanks!
- Hi Robert,
Thanks for posting. What OS version are you using? I would suggest running any Windows updates. Also you should check to make sure no third party tool bars or other extensions have been downloaded recently without your knowledge. Let us know if this helps.
Thank you,
Chris - Robert in NebraNot applicable
windows 7.. and far as I know, it's updated automatically.
I can't tell you at this time if something 'snuck' in as far as third party tool bars, or other extension.
I'll look around! Thanks
- Gwalk900Honorary Alumnus
Robert,
Have you tried another browser such as Opera or Firefox just to name a couple ?
Well, Dang! now everything is working properly.. I didn't change or do a thing different! No clue what happened, if was me, or hughes.. Drives me nutz when something suddenly 'cures' itself!
Gwalk900, I have not tried any other browser. I might some day, but for my needs, and lack of enthusiasm to try something different.. LOL, I'll probably stay with IE.
Until next time, Thanks!
- Glad everything is working!
- 2 months ago
