ETF Cost Question
Ryan11433 wrote:Oh of course when that time come I return the modem including AC adapter and the radio transmitter? or be charged 300? Is the radio transmitter on the dish?
Yes. The instructions for removing the radio, which will also be included in the equipment return box they send, are here.
If, for whatever reason, you're not able to retrieve the radio yourself, they can send a tech to remove it for you, but there is a charge. I think it's $125, but I'm not 100% on that.
thank you for the information I'm just getting prepared so I will know what to do when that time come that I move out back to Jacksonville in Mandarin area. Is Hughesnet supported in those area because I know Comcast uses landline and it does have outages almost all the time. Zip Code is 32223.
Go here: https://www.hughesnet.com
Enter your new address and it will show if there are plans there. Or enter a random address from the same area.
- Ryan114335 years agoJunior
I have not decided what house yet but I'm sure it is in the zip code 32223 area.
maratsade wrote:Go here: https://www.hughesnet.com
Good news it is supported...- maratsade5 years agoDistinguished Professor IV
I used a random address from that zipcode, and all plans seem to be available for the area. :)
