HughesNet Voice Activation
Hi Ricky,
Thanks for posting. I pulled up your account and I can also confirm that your VOIP service is active in our system, yet those e-mail have gone out. Let me check with our VOIP folks to see what's going on with that; I don't see why those e-mails should be sending.
BTW, the community ranks are not just based on length of membership, which is why newer members may outrank those who have joined earlier.
Hi Ricky,
I was given assurance that you won't be charged for not activating your ATA, especially since I see that the ATA is active. If anything odd happens, just let me know.
I can not believe I just called them. What a waste of my time.
I know you've been around for a while, Ricky; not sure why you feel the need to point this out. The title "professor" is just something the system gives (like "tutor"). Means nothing, and I was just attempting to help you, and it seems you may not have appreciated that. That's all right, no worries.
As you know, the reps are here M-F, so there won't be a reply from them until next week. Best of luck to you.
- 5 months ago
- 10 months ago
