Hushesnet lied to me
I cannot find the disclaimer anywhere
https://legal.hughesnet.com/ServiceTermsAndConditions-current.cfm
1.1 SPEED CLAIMS AND DISCLAIMERS.
Hughesnet service is available in the contiguous U.S., Alaska and Puerto Rico, except for Hughesnet Fusion plans which are only available in the contiguous U.S. Stated speeds, low-latency and uninterrupted use of the Service are not guaranteed. Actual speeds will likely be lower than the maximum speeds during peak hours. In addition, when connected to the Service using Wi-Fi, the user’s experience will vary based on the proximity to the Wi-Fi source and the strength of the signal.
Depending on your selected Hughesnet service plan, download speeds may be up to 100 Mbps and upload speeds may be up to 5 Mbps, or, in either case, as otherwise advertised by Hughes. All service plan speeds are “up to” and are not guaranteed. Listed or otherwise advertised speeds are associated with specific plans and may only be available in certain geographic areas. While Hughesnet Service is only available in the coverage area of the EchoStar XVII, EchoStar XIX, and EchoStar XXIV satellites within the contiguous United States, certain service plans may only be available in certain geographic areas. Speeds in parts of Alaska will be slower. Hughesnet Fusion plans are only available where adequate terrestrial wireless signal strength is available.
