Tony Walker
10 years agoNot applicable
I have a problem with performance
If u pay for something u should get it ,I don't feel we are getting what we are paying for
- MordaciousNot applicableYou're going to have to be a little more specific. Just what is it you feel you have paid for that you're not getting?
- BirdDogAssistant ProfessorCare to expound? That sure isn't telling us anything we can try to help with.
Grrrrrr.......Mordacious posted while I typed......foiled again! Tony I think you get the point. - Tony WalkerNot applicableI thought highs peed mentioned highspeeddidnt know it was same a 3 4g
- Tony WalkerNot applicableIt buffers all the time no matter if fb on phone or netflix
- BirdDogAssistant ProfessorWhat plan do you have? Speeds are advertised as "up to" and not guaranteed to be at top speed 24/7. The highest "up to speed" is 15 Mbps depending on plan.
- Tony WalkerNot applicableI called Hughes net to ck it and they want to charge me and said it was working fine .I have better service with my data on my phone and I'm in extended area with Verizon. That's why I got internet.not good at all
- MordaciousNot applicableIf your having trouble with buffering it is generally because you are trying to stream in HD and not SD. I stream all the time at SD with no problems
Speed are UPTO 10 MBPS run a speed test at testmy.net to see what your speeds are or use the Hughesnet site on your dashboard.
Curses BirdDog you beat me to it! - BirdDogAssistant ProfessorHow long have you had service and are you over your allowance? Are the boxes green at top of the page here: http://192.168.0.1/ ?
- Gwalk900Honorary Alumnus
First things first:
What modem do you have ? (HN9000 or HT1000/1100)
What plan level do you have ?
Check the modems SCC at 192.168.0.1 to see if you are in FAP or have an active error code.
Then once that info is known (it tells us how much "horsepower" you have) then we can look at streaming sources, streaming rates and speed tests.
- Tony WalkerNot applicableHt1100 all green lights
