john777
6 years agoSophomore
need to down grade from 50 gb to 30 gb plan no phone support
can some one help me i need to down grade my service plan from 50 gb to 30 gb is there any tech agents out there that could do that for me ?????????????
If you sign into the HughesNet My Account site, hover your pointer over Shop/Upgrade, then click on Plans & Pricing, you should be able to change plans there.
6 years agoModerator
Hi John,
Happy to see you received advice from Gabe. I see you were able to update your service plan last Thursday. Don't hesitate to drop by the community if you have other questions!
