Plan reset, lost tokens.
Hi fox12,
Thank you again for your patience and cooperation. I've sent you tokens to make up for all this. Please don't hesitate to stop by the community again if you have any other concerns.
Hi fox12,
I see it's your first post here, so welcome to the community! Thanks for much for reporting this ASAP, better we have a live, fresh case so that our engineers can have a look to see what's happening. We'll be sure to restore your data tokens once engineering has had a look first and deems it ok for me to send.
I'll post back once I have an update or any questions.
- C0RR0SIVE4 years agoAssociate Professor
I have also had a reset on all my terminals, not sure of my tokens as I never look at them, or buy them, or anything of the sort, but it appears this data reset and token issue might be a bit wider spread...
I bet if you look at your terminal status, it will show that you got reset as well.
- MarkJFine4 years agoProfessor
Hmm. My data seems correct on my Usage Meter, the iPhone app, as well as the web site.
That said, I've been noticing a tremendous (nearly painful) amount of SSL errors since late last week so I'm wondering if that's affecting authentication errors in many instances and it's causing data retrieval errors and possibly data corruption as a result.
- Liz4 years agoModerator
Oh I believe it C0RR0SIVE. I've been tracking this for a few months now. When did your data reset, today?
Edit, your DSS terminal is down so I can't check, but when is your normal reset date for that one?
- maratsade4 years agoDistinguished Professor IV
Cheers. I'll check when I get home. EDIT: data and tokens both correct on Website and HughesNet app. Can't check the SCC until later. EDIT 2: Data and tokens are correct on the SCC as well. No resets.
C0RR0SIVE wrote:I bet if you look at your terminal status, it will show that you got reset as well.
- fox124 years agoJunior
Thanks for the welcome Liz..It is my first post however I have read a lot. I haven't had to post, you and the others cover other members problems pretty well. I have gained a lot of insight just reading answers. I want to thank you all for the fine job you do
And also thanks for the very fast response to my situation, I am not worried I am sure you will find the problem.
Wishing you all a great day.- Liz4 years agoModerator
Your words mean a lot fox12, thank you! That is exactly what the community is for, and I'm so glad you've gained something from it.
We have a couple engineering teams investigating this issue now. I'm also looking forward to what happened and having this resolved soon.
