Plan reset, lost tokens.
Hi fox12,
Thank you again for your patience and cooperation. I've sent you tokens to make up for all this. Please don't hesitate to stop by the community again if you have any other concerns.
Hi fox12,
I see it's your first post here, so welcome to the community! Thanks for much for reporting this ASAP, better we have a live, fresh case so that our engineers can have a look to see what's happening. We'll be sure to restore your data tokens once engineering has had a look first and deems it ok for me to send.
I'll post back once I have an update or any questions.
I have also had a reset on all my terminals, not sure of my tokens as I never look at them, or buy them, or anything of the sort, but it appears this data reset and token issue might be a bit wider spread...
I bet if you look at your terminal status, it will show that you got reset as well.
- MarkJFine4 years agoProfessor
Hmm. My data seems correct on my Usage Meter, the iPhone app, as well as the web site.
That said, I've been noticing a tremendous (nearly painful) amount of SSL errors since late last week so I'm wondering if that's affecting authentication errors in many instances and it's causing data retrieval errors and possibly data corruption as a result.
- Liz4 years agoModerator
Oh I believe it C0RR0SIVE. I've been tracking this for a few months now. When did your data reset, today?
Edit, your DSS terminal is down so I can't check, but when is your normal reset date for that one?
Got it C0RR0SIVE, thanks.
Hardware upgrades on our end appear to have a hand in this. Our engineers are looking into a solution to prevent this as they continue to upgrade, was well as resolve any currently affected accounts.
I don't know when they will have a solution to restore tokens automatically, but if you are in need of your tokens sooner, fox12, please let me know. I can apply them after I check with engineering if it's ok to do so.
- maratsade4 years agoDistinguished Professor IV
Cheers. I'll check when I get home. EDIT: data and tokens both correct on Website and HughesNet app. Can't check the SCC until later. EDIT 2: Data and tokens are correct on the SCC as well. No resets.
C0RR0SIVE wrote:I bet if you look at your terminal status, it will show that you got reset as well.
