Help! Lost 8.5 GB in Data overnight!
There is no calibration issue. Sometimes the data takes a while to update from day to day, and that's not an error, it's a normal happening.
You are the only one who can figure out what ate your data, as the data-eating happened on your side of the modem. The modem itself does not eat your data; data is used when something on your side of the modem, on your network, is using it, as stated in the previous post.
You can try calling the customer service 24/7 phone line and see what troubleshooting steps the agent has for you.
The issue may be solved. The chart is not representative of the data on their system. When it spiked up, I thought my plan had reset, but then it corrected a day or so later. They're reporting the glitch so it gets fixed. Both the chart on their site and the control center on the router were affected by the glitch...showing the same numbers while their system had the actual statistics from daily and cumulative usage.
