if been having problems how can I get out of contract without early termination fees is there a way
If Netflix, best to set to low definition as explained here: Netflix Playback Setting
If YouTube, as soon as video starts use the gear icon to change definition to 360p or 244p, do not leave on auto or higher resolution. The 244p setting should look fine on smaller devices.
If any other streaming site, do not use if there is no adjustment for video definition that at least allows 360p or lower.
That's your guys solution for the customer tell them to settle for lower quality videos. I don't know if his/her service is like mine but I can't even get netflix to load even when I have Data to burn.
Come on though what's wrong with you people, that is your solution lower the quality? Would you buy a steak at a fancy restaurant for 20 bucks and be ok with getting a mcdouble from mcdonalds instead? No, you wouldn't, you would be upset and you would never go back to that restaurant again.
