maratsade, Yes. I switched from Spectrum after they bought out Brighthouse. I had Brighthouse for years with no issues, cancelled when I moved. I ended up at the same house years later and called them back out. I got them back, and was extremely satisfied with them, and they were able to use the original cable they already had here to hook me back up. Spectrum came along and my bill went up by $20/month. I talked them down and my very next statement they were telling me they were raising me again. So that is when I found Hughes. My community has no Fios, so there are not a lot of other options. But I will be happy to pay the higher price for Spectrum than to put up with this service. They told me when I called to disconnect, to let me know if I am unhappy (I have to wait 30 days with Hughes) with the new provider because they would buy me out. I am sure if they will do that, others will too. You have to ask, and most people don't. Good luck!!
Well, if you have a service you like, then you should switch back.... Sometimes you have to pay more to get what you need, though you sound like you might be able to negotiate a lower price for yourself! :smileyhappy: I have Verizon here, but it's not very good and it can be more expensive. I'm delighted with Hughesnet, as it works very well for me, but I know it doesn't work for everyone.
- TampaGal8 years agoSophomore
maratsade, yes Verizon is VERY expensive here and their customer service is horrible! I also have a pre-paid VOIP phone service that I can't use with Hughes and I watch movies with my Fire TV Stick, and those options being out are not making me at all happy. My room mate has a limited minute cell plan and is on a strick budget so he is not happy now either since he may end up with no phone use within the next few weeks. He is disabled and if he has an emergency and can't call out, that would be horrible. I think he can still dial 911 with no service, but am not sure. Either way, he is not loving this, either. I am glad that you are satisfied with Hughes! I had hoped I would be too. Everyone has different needs and methods with which they use their service. It's good to hear from you - enjoy your weekend!
- 8 months ago
- 11 days ago
- 12 months ago
