Repair Irony
So why did the first and second tech feel it was part of their job to move it?
Because relocating the equipment is part of their job.
By the way, were you asked to sign off on the job, and if so, did you?
You will most likely be charged, as according to the subscriber agreement, "Any reinstallation, return, or change in the location of the Equipment shall be performed by us at our service rates in effect at the time of such service." (Part 1.2)
You have complained about the relocation (as is your right as a consumer), but you have not said what redress you expect from the company. You may have noticed that no rep has replied to you; this may mean they are waiting for you to state how you would like them to address the situation.
So "Distinguished Professor IV" "GabeU" said that "That the second tech tried to remove the original pole was Kind." and that they are not required to move it. So then I asked why the first and second tech felt it was part of their job to move it? Which is the whole reason why the first tech did not complete the work, because he was unable to get the pole out!
So then "Distinguished Professor III" "Maratsade" responded to my question "So why did the first and second tech feel it was part of their job to move it?" by saying "Because relocating the equipment is part of their job." Seriously? Can you all get on the same page?
By the way, were you asked to sign off on the job, and if so, did you? No and No
You have complained about the relocation (as is your right as a consumer), but you have not said what redress you expect from the company. You may have noticed that no rep has replied to you; this may mean they are waiting for you to state how you would like them to address the situation. I just do not want to pay for a halfway complete job. Can I dig out that pole with a mass of concrete on the end of it? I'm sure I can and will have to. Can I dispose of it? Sure, I can haul and pay the dump fee. Just don't feel like I should be charged the full service fee for an incomplete job.
Also, I am just bitter that I am locked into a service agreement paying by far more than I ever had for internet service and receiving the absolute worst internet service in return. I would not mind paying the astronomically high bill each month (I knew what the price was when I signed up) if I was getting something in return. What I get in return is terrible internet service that is metered and ends up burning through most all of my data trying to load a webpage or buffering a video usually all before timing out and having to start all over. Yet Hughesnet customer support says "I show you're connected and are receiving great service." Garbage! There is obviously a disconnect.
I sympathise with your frustration. Hopefully a rep will get involved.
Next to your name it says "new member." That's a system given label. So is "distinguished professor." We have no control over the system labels.
Distinguished Professor I-V
Professor
Senior Instructor
Instructor
Adjunct Instructor
Teaching Assistant
Advanced Tutor
Tutor
Senior
Junior
New PosterLurker rankings:
Scholar
Researcher
Learner
Observer
Spectator
New Member- bstaffo5 years agoFreshman
Thank you
bstaffo wrote:I just do not want to pay for a halfway complete job. Can I dig out that pole with a mass of concrete on the end of it? I'm sure I can and will have to. Can I dispose of it? Sure, I can haul and pay the dump fee. Just don't feel like I should be charged the full service fee for an incomplete job.
Their job IS complete. Your service is installed at the new location of your request. Removal of the old pole and disposal is not part of their work. That's the homeowner's responsibility. If you ever have a DirecTV pole installation moved, you will be dealing with the same thing.
If the agreement prior to the work being started was stipulated that removal of the old pole was part of the job and you had paid the subcontractor separately for that removal, then that's different. In that case, you're complaint would be with the subcontractor who performed the work, and they absolutely should finish the job.
With this said, I can't speak to what HughesNet may or may not do for you regarding the pole issue.
bstaffo wrote:Also, I am just bitter that I am locked into a service agreement paying by far more than I ever had for internet service and receiving the absolute worst internet service in return. I would not mind paying the astronomically high bill each month (I knew what the price was when I signed up) if I was getting something in return. What I get in return is terrible internet service that is metered and ends up burning through most all of my data trying to load a webpage or buffering a video usually all before timing out and having to start all over. Yet Hughesnet customer support says "I show you're connected and are receiving great service." Garbage! There is obviously a disconnect.
If you're having issues with buffering, one thing you can try turning off or pausing the Video Data Saver. Keep in mind, however, that satellite internet is not the same as ground based internet, and the higher latency affects things in different ways.
I'm not sure what you're referring to with "metered", but service speed is only throttled when you run out of plan data. That doesn't mean that you won't experience slowdowns, however, which are the result of system load. Streaming speed may be reduced to around 3Mbps, but that can be disabled by the pausing or turning off of the Video Data Saver. However, again, how a streaming service reacts to HughesNet's high latency is something HughesNet can't control.
If you're having speed issues and would like help, the reps here will need some speed tests to be run using the following protocol as a first step....
-if testing upload instead of download, use the manual 4MB size upload test file
