Told wrong information
Paula,
I see it's your first post here, thank you very much for reaching out! I can understand your frustrations completely, especially if you were told something different to begin with. I'm going to go ahead and place a request for the call to be reviewed, and I'll be back shortly with results. It normally takes between 1-3 days for the call to be pulled and reviewed, just to give you a heads up!
Remy
- Remy6 years agoModerator
Paula,
I went ahead and edited the message for you, and took out the number! I also got a response in regards to the sales call. Unfortunately, we were unable to locate the sales call, as we normally only keep the sales calls up to a year. In this case, the call was over a year and a half ago, and the service has been in use since then. In regards to the bills, HughesNet policy states that you have up to 15 days after the bill is generated to dispute the charges, and we would still need payment for the services regardless. We apologize for the inconvenience, and would recommend speaking with your mother in regards to the past payments. The previous agent you spoke with removed the card on file, so you will not be charged to that previous card going forward.
Remy
