Quinatt
6 years agoFreshman
Data tokens vs plan upgrade
First month with hughesnet. On the 10gb plan and I see that the upgrade to 10gb more is only $10 more. Then I see to purchase 10gb tokens is $30?? Can I not upgrade my plan mid month for the $10 more...
Upgrading might be better for you, but you will still have to learn to budget your data, or you'll run out of data on any of the plans.
Can I not upgrade my plan mid month for the $10 more? I have to buy the hugely more expensive tokens? Pretty sure I’m going to use all 10gb this month but not sure. What’s the best thing to do? Don’t want to have to buy the expensive tokens
