Furnace woes....
@@@GabeU wrote:
....................................................................................................................... To be honest, as choked as the supply side has been, I'm shocked that the blower motor hasn't died, as it's under a of stress trying to push the proper amount of air through openings (the registers) that are too small. It's almost like trying to breathe through a straw.
Take it from this old retired industrial electrician ( 20 years ), it's actually just the opposite, the amp load on a centrifugal blower or pump actually goes down, if the discharge is restricted.
Sorry to hear about your problems though, With a house, it seems like it's always something. Mine is fifteen years old, and I just replaced my AC ($3800 ), bladder tank ($400), and water heater ($400). I also just had a whole house generator installed ($11500). Now I worry about the well ($4500), and septic tank drain field ($2500). Ah, but the joys of country living!
BTW I hear the summer is real nice up by the lake where you live -- all three days of it! :>)>
"O Oysters,' said the Carpenter,
You've had a pleasant run!
Shall we be trotting home again?'
But answer came there none —
And this was scarcely odd, because
They'd eaten every one."
Lewis Carroll
