ChrisVZ
9 years agoSophomore
Horrible Upload Speed, Week 3
Not looking for tech support, just an informational post. I've seen tons of posts lately about poor performance of the network. You are not alone. For 3 weeks now I have also been having issues. ...
MarkJFine
9 years agoProfessor
Then what's the point of just complaining on a site designed for user support?
Just venting because you can?
ChrisVZ
MarkJFine wrote:Then what's the point of just complaining on a site designed for user support?
Yep. When my connection is so poor I cannot use it as I wish, I will vent. What better place than where others are experiencing the same issues?
ChrisVZ wrote:
What better place than where others are experiencing the same issues?Maybe because it's generally annoying and not helpful to anyone?
It also just makes you look like a kvetch.
- ChrisVZ9 years agoSophomore
MarkJFine wrote:It also just makes you look like a kvetch.
So does attacking people on the internet....
Sorry you thought I was attacking you. Never mind that we're being assaulted with hollow complaints.
Suggest you look up 'kvetch' if that bothered you.
