I'm sure MarkJFine can provide a suitable explanation. But you should take your posting to the General Discussion section, because this section is for Tech Support, and you're not requesting any tech support.
Maybe the mods can move the conversation to General Discussion.
I provided a truthful explanation of why there is a base latency and provided a means to determine where the problem is.
The OP decided not to comply and gave a fairly paranoid and accusatory reason why.
So respectfully, I'm deciding from entertaining this circular conversation any longer before someone gets angry.
Sounds good to me.
MarkJFine wrote:I provided a truthful explanation of why there is a base latency and provided a means to determine where the problem is.
