Cblucas3
7 years agoFreshman
There is all this talk of distance affecting latency which doesn't seem to wash. If the signal has to travel 88,000 miles latency shouldn't be an issue when the speed of light is considered. Traveling...
MarkJFine
7 years agoProfessor
Yes, you are paranoid. That's a perfectly good traceroute for satellite comms. There's not one hop in there that takes 2 minutes like you said. Plus, none of the timeouts have anything to do with HughesNet - at all.
But just because it took me to embarrass you into FINALLY giving a traceroute snapshot like I originally asked, I'm not going to tell you the reason why your latency is so bad, because your paranoid delusions wouldn't believe it anyway.
Cblucas3
7 years agoFreshman
My God, you can't see where it times out twice? I'm truly am wasting my time here.
