MarkJFine
8 years agoProfessor
MacBook Pro Battery/Trackpad Repair
If you have a MacBook Pro that's been in heavy use for 5 years, chances are (like me) your internal battery is toast. Li-Ion batteries tend to swell when they're beginning the death knell, and suc...
MarkJFine
Actually, what they recommend is a thread soaked in rubbing alcohol. It supposedly breaks down the adhesive cleanly, but that still sounds a bit messy to me.
I recently bought a Tekton kit off of Amazon that's a tinkerer's dream. Not only has the PL1.2 and T4 bits needed to uncork all the screws, but has a magnetic mat to keep them in one place when you've taken them out (and geometrically positioned to where you got them from - I like screws to go back exactly where they came from). But it also came with these two. Came in real handy here.
alfresco
8 years agoSenior
I'm going to have to get me one of those Tekton kits:smileyhappy: Hopefully my wife has enough in her pay pal. :smileyhappy:
