I've been reading here about a some peoples problems with power failures, so I thought I'd post the method I used during the many power failures I had before I got a whole house generator.
I had a portable generator with enough capacity to run my lights and ceiling fans, fridge, freezer, microwave, toaster oven, well pump, and one small window AC. An easy way to do this is to buy a generator with enough capacity to have a dryer receptacle. Then you construct a cable with 10/4 portable cord with a male dryer plug at each end.
During a power failure you turn off the following breakers: main, dryer, water heater, central heat & AC, stove, water pump, and any other large loads. Plug one end of the temporary cord into the generator before it's started, run the other end of the cord into the laundry area and plug it into the dryer receptacle, start the generator, and close the main on the generator.
Then you close the dryer breaker at the main panel. If you have done every thing correctly you now have power to all the essentials, without having to run extension cords all over the place.
Keep in mind that you've only got about 30 amps available, and the more stuff you have powered on, the faster the generator will run out of fuel. Never turn on the central heat & AC breakers, as this would probably immediately trip the generator. Don't use more than one burner or the oven on the stove, unless you turn off the water heater, well pump breakers, and the window unit AC. IOW you have to actively manage the loads.
To test if the utility power has returned you only have to open the dryer breaker, and close the main. Make absolutely sure that both breakers are never closed at the same time until the generator is disconnected. With the newer electric meters, this test is not necessary. you can just look at the LC display on the meter. If it's back on, you have power.
If the power has returned, open the dryer breaker, and close the main and any other open breakers, shut down the generator and remove the temporary cable, plug the dryer back in, and then close the dryer breaker at the main panel.
Simple yes? I got so tired of doing the this in the middle of the night by flashlight, that after my portable generator was stolen, and I had gone through a 38 hour outage without it, I had a whole house generator installed. Expensive, but I was getting too old to stumble around in the dark with a flashlight anyway. It also has the advantage of using propane for fuel, and it came with a 250 gal tank.
The generator was installed three months ago, and we haven't had a power failure since. Just a few glitches that didn't last long enough for it to even start its warm up cycle.
See, my expensive new generator is working very well! :>)>
","kudosSumWeight":1,"postTime":"2019-02-27T12:49:28.805-05:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuMnwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:general discussion is not a support area","text":"general discussion is not a support area","time":"2018-09-10T13:02:20.678-04:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:110367_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":10613},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"customFields":[]},"Conversation:conversation:110367":{"__typename":"Conversation","id":"conversation:110367","solved":false,"topic":{"__ref":"ForumTopicMessage:message:110367"},"lastPostingActivityTime":"2019-03-01T09:07:10.105-05:00","lastPostTime":"2019-03-01T09:07:10.105-05:00","unreadReplyCount":20,"isSubscribed":false},"ModerationData:moderation_data:110367":{"__typename":"ModerationData","id":"moderation_data:110367","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:110367_1":{"__typename":"Revision","id":"revision:110367_1","lastEditTime":"2019-02-27T12:49:28.805-05:00"},"ForumReplyMessage:message:110393":{"__typename":"ForumReplyMessage","id":"message:110393","conversation":{"__ref":"Conversation:conversation:110367"},"author":{"__ref":"User:user:64574"},"revisionNum":1,"uid":110393,"depth":4,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"subject":"Re: Power failures","readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:110393"},"parent":{"__ref":"ForumReplyMessage:message:110384"},"body":"
GabeU wrote:
The only caveat I would add is that, if someone is going to do this, they install, or have installed, an interlock switch. Though remembering to turn off the main is something that has to be done, people forget things, and accidentally powering the generator while the main is still on could cause considerably injury to a linesman or someone else working on the mains.
Like I said to birdog, the utility companies are well aware of all the generators around, and take precautions.
I think the most likely occurrence would be that your running generator would try to pick up all the loads between you and the fault on the line. If the generator was down and the power came back on with the main and dryer breakers closed, the utility power would try to motorise your generator. Neither situation would be good for the generator even though a breaker would probably trip somewhere.
My dryer receptacle was actually located in a detached pole barn about 70 feet from the house with a hundred amp service feeding a separate panel from the main house. Installing any sort of interlock would have been tricky to say the least.
Well like I said, I don't have to worry about it any more.
","body@stringLength":"1836","rawBody":"
","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-02-28T04:17:19.180-05:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:110393_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":10385},"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1742461836141":{"__typename":"CachedAsset","id":"theme:customTheme1-1742461836141","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"rebrand-favicon-1721032736485.png","imageLastModified":"1721032741408","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"HughesnetLogo-1721027846492.png","imageLastModified":"1721027849927","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1200px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"22px","paddingXLg":"24px","paddingXHero":"56px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.16)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.12)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"#005DAC","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#4099E2","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#005DAC","secondary":"#333333","bodyText":"#000000","bodyBg":"#F7F7F8","info":"#409AE2","success":"#41C5AE","warning":"#FCB116","danger":"#DE3700","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#00223A","#0096FA","#0E4275","#005DAC","#1C475A","#00223A","#0E4275","#FF0000","#0099AA","#582596","#660099","#0000FF","#0066FF","#006600","#009900","#00CC00","#33CC00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":null,"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Montserrat","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"34px","h2FontSize":"28px","h3FontSize":"18px","h4FontSize":"18px","h5FontSize":"18px","h6FontSize":"18px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":null,"size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","formTextMarginTop":"4px","textAreaBorderRadius":"20px","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"15px","defaultMessageHeaderMarginBottom":"15px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"16px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"15px","specialMessageHeaderMarginBottom":"15px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"16px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Source Sans Pro","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"15px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Axiforma-Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["Axiforma-Regular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Source Sans Pro","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["SourceSansPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:hughes.prod:pages/forums/ForumMessagePage:board:General-1742461834266":{"__typename":"CachedAsset","id":"quilt:hughes.prod:pages/forums/ForumMessagePage:board:General-1742461834266","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":null,"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"custom.widget.MixPanelTracker","className":null,"props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1739990369000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1739990369000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:hughes.prod:Common:1742461763672":{"__typename":"CachedAsset","id":"quiltWrapper:hughes.prod:Common:1742461763672","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"46px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-primary)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-dark)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-body-bg)","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-bg)"},"__typename":"QuiltComponent"},{"id":"custom.widget.GoogleTagTracker","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"cProp_gtag":"G-JZZW630G5D","useBackground":false,"title":"","lazyLoad":false,"widgetChooser":"custom.widget.GoogleTagTracker"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#00223A","items":[{"id":"custom.widget.custom_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1739990369000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.GoogleTagTracker-en-1742461847667":{"__typename":"CachedAsset","id":"component:custom.widget.GoogleTagTracker-en-1742461847667","value":{"component":{"id":"custom.widget.GoogleTagTracker","template":{"id":"GoogleTagTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GoogleTagTracker","form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"__typename":"Component","localOverride":false},"globalCss":null,"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"}},"localOverride":false},"CachedAsset:component:custom.widget.MixPanelTracker-en-1742461847667":{"__typename":"CachedAsset","id":"component:custom.widget.MixPanelTracker-en-1742461847667","value":{"component":{"id":"custom.widget.MixPanelTracker","template":{"id":"MixPanelTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.MixPanelTracker","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.custom_Footer-en-1742461847667":{"__typename":"CachedAsset","id":"component:custom.widget.custom_Footer-en-1742461847667","value":{"component":{"id":"custom.widget.custom_Footer","template":{"id":"custom_Footer","markupLanguage":"HTML","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.custom_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Navbar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1739990369000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","external-1":" My Email","external-10":"child 1","mucxz84639":"Home","about-community":"About the Community","external":"Test","external-9":"Bill History","external-8":"Bill Summary","external-7":"Pay Now","mucxz84639-1":"Billing","external-6":"Alerts","external-5":"Service Repair Order","external-4":"My Services & Plan","external-3":"Manage Username / Logins","external-2":"My Information"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1739990369000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1739990369000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1739990369000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1739990369000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1739990369000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1739990369000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1739990369000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1739990369000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1722231399124":"Latest Posts","title@instance:1722321652654":"Recent Content","title@instance:1721715590817":"Latest Posts","title@instance:1722251112371":"Latest Posts"},"localOverride":false},"Conversation:conversation:143653":{"__typename":"Conversation","id":"conversation:143653","topic":{"__typename":"ForumTopicMessage","uid":143653},"lastPostingActivityTime":"2025-03-10T17:26:54.014-04:00","solved":false},"ForumTopicMessage:message:143653":{"__typename":"ForumTopicMessage","subject":"Rebate ?","conversation":{"__ref":"Conversation:conversation:143653"},"id":"message:143653","revisionNum":1,"uid":143653,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":123656,"login":"Kat3","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":67},"postTime":"2025-03-10T04:06:47.572-04:00","lastPublishTime":"2025-03-10T04:06:47.572-04:00","readOnly":false},"Conversation:conversation:143640":{"__typename":"Conversation","id":"conversation:143640","topic":{"__typename":"ForumTopicMessage","uid":143640},"lastPostingActivityTime":"2025-02-26T18:28:32.582-05:00","solved":false},"ForumTopicMessage:message:143640":{"__typename":"ForumTopicMessage","subject":"Not worth it!","conversation":{"__ref":"Conversation:conversation:143640"},"id":"message:143640","revisionNum":1,"uid":143640,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":152411,"login":"dena629","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":76},"postTime":"2025-02-26T12:00:36.392-05:00","lastPublishTime":"2025-02-26T12:00:36.392-05:00","readOnly":false},"Conversation:conversation:143633":{"__typename":"Conversation","id":"conversation:143633","topic":{"__typename":"ForumTopicMessage","uid":143633},"lastPostingActivityTime":"2025-02-26T18:25:57.733-05:00","solved":false},"ForumTopicMessage:message:143633":{"__typename":"ForumTopicMessage","subject":"Service & billing","conversation":{"__ref":"Conversation:conversation:143633"},"id":"message:143633","revisionNum":1,"uid":143633,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":152392,"login":"puffpuff1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":144},"postTime":"2025-02-25T11:44:00.049-05:00","lastPublishTime":"2025-02-25T11:44:00.049-05:00","readOnly":false},"Conversation:conversation:143385":{"__typename":"Conversation","id":"conversation:143385","topic":{"__typename":"ForumTopicMessage","uid":143385},"lastPostingActivityTime":"2024-12-31T22:46:43.455-05:00","solved":false},"ForumTopicMessage:message:143385":{"__typename":"ForumTopicMessage","subject":"Very, very poor support","conversation":{"__ref":"Conversation:conversation:143385"},"id":"message:143385","revisionNum":1,"uid":143385,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":151477,"login":"themgman","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-2.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":127},"postTime":"2024-12-31T20:36:47.442-05:00","lastPublishTime":"2024-12-31T20:36:47.442-05:00","readOnly":false},"Conversation:conversation:143384":{"__typename":"Conversation","id":"conversation:143384","topic":{"__typename":"ForumTopicMessage","uid":143384},"lastPostingActivityTime":"2024-12-31T22:42:33.827-05:00","solved":false},"ForumTopicMessage:message:143384":{"__typename":"ForumTopicMessage","subject":"Hughesnet is a total rip-off","conversation":{"__ref":"Conversation:conversation:143384"},"id":"message:143384","revisionNum":1,"uid":143384,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":151476,"login":"donnaneal1964","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":135},"postTime":"2024-12-31T20:13:52.796-05:00","lastPublishTime":"2024-12-31T20:13:52.796-05:00","readOnly":false},"Rank:rank:21":{"__typename":"Rank","id":"rank:21","position":22,"name":"Freshman","color":"33CC00","icon":null,"rankStyle":"TEXT"},"User:user:97278":{"__typename":"User","id":"user:97278","uid":97278,"login":"Cabooose2","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-01-22T19:06:19.053-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:21"},"messagesCount":8,"kudosGivenCount":2,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:97278"},"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}":{"__typename":"AssociatedImage","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130","mimeType":"image/png"},"Forum:board:TechSupport":{"__typename":"Forum","id":"board:TechSupport","entityType":"FORUM","displayId":"TechSupport","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Tech Support","shortTitle":"Tech Support","parent":{"__ref":"Category:category:HNSupport"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}"},"description":"Tips and tricks to getting the most out of your Hughesnet internet and Hughesnet Voice services.","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/"},"ForumTopicMessage:message:137939":{"__typename":"ForumTopicMessage","uid":137939,"subject":"Phone failure","id":"message:137939","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:97278"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:137939"},"moderationData":{"__ref":"ModerationData:moderation_data:137939"},"postTime":"2022-06-28T14:52:55.332-04:00","lastPublishTime":"2022-06-28T14:52:55.332-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":3611},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:137939"},"Conversation:conversation:137939":{"__typename":"Conversation","id":"conversation:137939","solved":true,"topic":{"__ref":"ForumTopicMessage:message:137939"},"lastPostingActivityTime":"2022-06-29T14:11:01.216-04:00","lastPostTime":"2022-06-29T14:11:01.216-04:00"},"ModerationData:moderation_data:137939":{"__typename":"ModerationData","id":"moderation_data:137939","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:137939":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:137939","relatedMessage":{"__ref":"ForumTopicMessage:message:137939"}},"Rank:rank:20":{"__typename":"Rank","id":"rank:20","position":21,"name":"Sophomore","color":"00CC00","icon":null,"rankStyle":"TEXT"},"User:user:11656":{"__typename":"User","id":"user:11656","uid":11656,"login":"Geoffrey Leach","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-07-13T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-1.svg?time=0"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":62,"kudosGivenCount":4,"kudosReceivedCount":8,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:11656"},"ForumTopicMessage:message:123397":{"__typename":"ForumTopicMessage","uid":123397,"subject":"Mail delivery failure","id":"message:123397","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:11656"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:123397"},"moderationData":{"__ref":"ModerationData:moderation_data:123397"},"postTime":"2020-04-21T09:32:53.971-04:00","lastPublishTime":"2020-04-21T09:32:53.971-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":16096},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:123397"},"Conversation:conversation:123397":{"__typename":"Conversation","id":"conversation:123397","solved":true,"topic":{"__ref":"ForumTopicMessage:message:123397"},"lastPostingActivityTime":"2020-04-21T11:29:02.040-04:00","lastPostTime":"2020-04-21T11:29:02.040-04:00"},"ModerationData:moderation_data:123397":{"__typename":"ModerationData","id":"moderation_data:123397","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:123397":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:123397","relatedMessage":{"__ref":"ForumTopicMessage:message:123397"}},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":19,"name":"Senior","color":"006600","icon":null,"rankStyle":"TEXT"},"User:user:65203":{"__typename":"User","id":"user:65203","uid":65203,"login":"hamradio","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2018-05-21T23:12:29.890-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS02NTIwMy01MDI4aUM0Q0RFQTRENzkwNzBBMEQ"},"rank":{"__ref":"Rank:rank:18"},"messagesCount":204,"kudosGivenCount":7,"kudosReceivedCount":29,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:65203"},"ForumTopicMessage:message:122529":{"__typename":"ForumTopicMessage","uid":122529,"subject":"Modem / Connection failure","id":"message:122529","revisionNum":1,"repliesCount":9,"author":{"__ref":"User:user:65203"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:122529"},"moderationData":{"__ref":"ModerationData:moderation_data:122529"},"postTime":"2020-04-07T15:01:39.745-04:00","lastPublishTime":"2020-04-07T15:01:39.745-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":7017},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:122529"},"Conversation:conversation:122529":{"__typename":"Conversation","id":"conversation:122529","solved":true,"topic":{"__ref":"ForumTopicMessage:message:122529"},"lastPostingActivityTime":"2020-04-10T16:31:30.420-04:00","lastPostTime":"2020-04-10T16:31:30.420-04:00"},"ModerationData:moderation_data:122529":{"__typename":"ModerationData","id":"moderation_data:122529","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:122529":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:122529","relatedMessage":{"__ref":"ForumTopicMessage:message:122529"}},"User:user:104672":{"__typename":"User","id":"user:104672","uid":104672,"login":"EMZ","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-04-14T18:49:42.857-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-2.svg?time=0"},"rank":{"__ref":"Rank:rank:21"},"messagesCount":8,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:104672"},"ForumTopicMessage:message:125076":{"__typename":"ForumTopicMessage","uid":125076,"subject":"e-mail delivery failure - 2","id":"message:125076","revisionNum":1,"repliesCount":19,"author":{"__ref":"User:user:104672"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:125076"},"moderationData":{"__ref":"ModerationData:moderation_data:125076"},"postTime":"2020-06-22T09:16:01.768-04:00","lastPublishTime":"2020-06-22T09:16:01.768-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":9390},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:125076"},"Conversation:conversation:125076":{"__typename":"Conversation","id":"conversation:125076","solved":true,"topic":{"__ref":"ForumTopicMessage:message:125076"},"lastPostingActivityTime":"2020-08-10T12:46:20.515-04:00","lastPostTime":"2020-08-10T12:46:20.515-04:00"},"ModerationData:moderation_data:125076":{"__typename":"ModerationData","id":"moderation_data:125076","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:125076":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:125076","relatedMessage":{"__ref":"ForumTopicMessage:message:125076"}},"User:user:24369":{"__typename":"User","id":"user:24369","uid":24369,"login":"bcam3601","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-08-09T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:21"},"messagesCount":9,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:24369"},"ForumTopicMessage:message:81688":{"__typename":"ForumTopicMessage","uid":81688,"subject":"Customer Service Failures","id":"message:81688","revisionNum":2,"repliesCount":1,"author":{"__ref":"User:user:24369"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:General"},"conversation":{"__ref":"Conversation:conversation:81688"},"moderationData":{"__ref":"ModerationData:moderation_data:81688"},"postTime":"2017-08-14T03:31:39.485-04:00","lastPublishTime":"2017-08-14T03:47:36.944-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4616},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:General/message:81688"},"Conversation:conversation:81688":{"__typename":"Conversation","id":"conversation:81688","solved":true,"topic":{"__ref":"ForumTopicMessage:message:81688"},"lastPostingActivityTime":"2017-08-14T12:17:23.152-04:00","lastPostTime":"2017-08-14T12:17:23.152-04:00"},"ModerationData:moderation_data:81688":{"__typename":"ModerationData","id":"moderation_data:81688","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:81688":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:81688","relatedMessage":{"__ref":"ForumTopicMessage:message:81688"}},"CachedAsset:text:en_US-components/nodes/NodeLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1739990369000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1739990369000","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1739990369000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1739990369000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1739990369000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1739990369000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1739990369000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1739990369000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1739990369000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1739990369000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1739990369000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1739990369000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1739990369000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1739990369000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1739990369000","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"ModerationData:moderation_data:110393":{"__typename":"ModerationData","id":"moderation_data:110393","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ModerationData:moderation_data:110384":{"__typename":"ModerationData","id":"moderation_data:110384","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"User:user:29869":{"__typename":"User","id":"user:29869","login":"GabeU","uid":29869,"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yOTg2OS0zMzc1aTM2QzZDMjdBOUREQzBFNDg"},"rank":{"__ref":"Rank:rank:5"},"email":"","messagesCount":12251,"biography":null,"topicsCount":305,"kudosReceivedCount":3708,"kudosGivenCount":6438,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2016-01-04T03:00:00.000-05:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":269},"Rank:rank:5":{"__typename":"Rank","id":"rank:5","position":6,"name":"Distinguished Professor IV","color":"0000FF","icon":null,"rankStyle":"TEXT"},"ForumReplyMessage:message:110384":{"__typename":"ForumReplyMessage","id":"message:110384","revisionNum":1,"uid":110384,"depth":3,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"conversation":{"__ref":"Conversation:conversation:110367"},"subject":"Re: Power failures","readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:110384"},"body":"
The only caveat I would add is that, if someone is going to do this, they install, or have installed, an interlock switch. Though remembering to turn off the main is something that has to be done, people forget things, and accidentally powering the generator while the main is still on could cause considerably injury to a linesman or someone else working on the mains.
A nifty trick, though. I've known people who have connected their portable generators with a cord like this in order to keep their refrigerators/freezers powered, as well as a few other things.
","body@stringLength":"856","rawBody":"
","author":{"__ref":"User:user:29869"},"isEscalated":null,"postTime":"2019-02-27T19:50:05.035-05:00","solution":false,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[],"kudosSumWeight":0,"repliesCount":1,"images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:110384_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":10411},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"Revision:revision:110393_1":{"__typename":"Revision","id":"revision:110393_1","lastEditTime":"2019-02-28T04:17:19.180-05:00"},"QueryVariables:ReplyList:message:110393:1":{"__typename":"QueryVariables","id":"ReplyList:message:110393:1","value":{"id":"message:110393","first":10,"sorts":{"postTime":{"direction":"ASC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1739990369000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1739990369000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1739990369000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1739990369000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false},"Revision:revision:110384_1":{"__typename":"Revision","id":"revision:110384_1","lastEditTime":"2019-02-27T19:50:05.035-05:00"},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1739990369000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"General","messageSubject":"power-failures","messageId":"110367","replyId":"110393"},"buildId":"q_bLpq2mflH0BeZigxpj6","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"hughes","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","./components/customComponent/CustomComponentContent/HtmlContent.tsx","./components/customComponent/CustomComponentContent/CustomComponentScripts.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[{"id":"mixPanel","src":"https://community.hughesnet.com/t5/s/ssqng67387/pagescripts/1733832053000/mixPanel.js?page.id=ForumReplyPage&entity.id=board%3AGeneral&entity.id=message%3A110393","strategy":"afterInteractive"}]}
