Yes, you are paranoid. That's a perfectly good traceroute for satellite comms. There's not one hop in there that takes 2 minutes like you said. Plus, none of the timeouts have anything to do with HughesNet - at all.
But just because it took me to embarrass you into FINALLY giving a traceroute snapshot like I originally asked, I'm not going to tell you the reason why your latency is so bad, because your paranoid delusions wouldn't believe it anyway.
OK.
Cblucas3 wrote:
That's it I'm reporting this. - MarkJFine7 years agoProfessor
Folks... I got better things to do today... Now I'm really out.
- Cblucas37 years agoFreshman
Got off the phone with Corporate Executive Care. I reported th slander and accusations when I was just trying to sound my thoughts on why. The fellow asked me if the modem was near anything that can interfere. Wow, so simple and I didn't consider it so I don't blame you guys either. My medical monitoring device was apparently interfering with it. It operates via cellular network. I moved it, ran a trace and ping and no timeouts and no extreme latency.
Next time "Professors" offer suggestions instead of belittling a person.
And thank you for literally wasting everybody's time.
Cblucas3 wrote:Next time "Professors" offer suggestions instead of belittling a person.
You mean like this?
"If you don't have an ethernet cable do it via WiFi, but be aware that, if your WiFi connection is weak, it can cause the results to be highly inaccurate."
That includes interference. So get off your high horse.
- Cblucas37 years agoFreshmanMy apologies. I did not equate weak signal with interference. Throughout all this I was always getting a strong signal (5 bars) using various tools to check it with. Corporate suggested that although I was getting a strong signal it was being scrambled, hence interference. So I missed the shuttle suggestion you had implanted somewhere in your post. After reading this and doing the trace via WiFi I checked for signal strength but missed your instructions on interference. Once again my apologies. I've gone through the posts and still can't find any mention of interference, just signal strength which was above nominal.
Cblucas3 wrote:
So I missed the shuttle suggestion you had implanted somewhere in your post.There was no "subtle suggestion implanted somewhere" in my post. A "weak signal" normally refers to intensity, but it's not the only thing it refers to.
Good day to you.
- Cblucas36 years agoFreshmanSignal strength, whether weak or strong, is not the same as interference. A "strong" signal can be affected by a source of interference. This would be a electromagnetic source causing this. So, as you can see, I'm still riding high.
Off Hughes website: Cellular Backhaul
Ideally suited to deliver affordability, efficiency and capability:Delivers round trip latency less than 600 ms and jitter of approximately 10 ms.
This validates my claim with latency explanation being a farce. If their system can do 600ms for backhaul with the same satellite at the same distance it can be done for consumer retail customers. The satellite or system regulates the response and prioritizes with enterprise customer getting the highest.
