klimshelf
5 years agoFreshman
connecting a yagi directional antenna
Is there a way to connect a yagi directional antenna cable directly to the HT2000W modem? Looks like a LAN connector is the obvious option on the modem but is there an adapter that will connect the LA...
If you mean using a yagi to beam the wifi, I'm pretty certain you can't do that with this modem. You have to use the internal omnidirectional antenna, which is matched to the wifi chip, or whatever setup you have using an external router.
MarkJFine
5 years agoProfessor
klimshelf
5 years agoFreshman
That's pretty much what I figured, but thought it was worth asking of people who know more than me. I'll continue using the router with yagi attached. Thanks for your replies.
- 11 months ago
