Connectivity issues
Jordan,
I see it's your first post here. Welcome to the Community! I was able to get your account pulled up and take a look into the issues you've been experiencing, as well as the State Codes you gave. From what I was able to look into, it seems your dish is out of alignment, which would be causing the errors you've been encountering, as well as the slow speeds. I went ahead and set up a technician for you to come realign the dish, and waived the associated fees. The tech will be arriving at our earliest available date, Monday, Aug 17, 2020 between 08:00 AM-11:00 AM. The technician will call beforehand, and if needed, you can take that time to reschedule. Please let us know how the visit goes!
Remy
- MarkJFineProfessor
30.1.1. just means web acceleration is in a backed off state. Sometimes it gets stuck.
Try going here using a computer connected to the modem and look for the current state code. If it still says 30.1.1, then go here. If it says "Web Acceleration Disabled" on a yellow button, then just click it to re-enable it.
Otherwise:
1. Click the green "Web Acceleration Enabled" to disable it,2. Click "Reset MBX" and wait a few seconds,
3. Click the "Web Acceleration Disabled" to re-enable it.
- Jordan567New PosterThat seems to have resolved the original issue, but now I'm getting 23.1.4. That just cleared a few minutes ago, and the system status page looked good. But still no connection. Ran the connectivity test and it says "unable to resolve gateway" and "you do not have connectivity to the gateway". Go back the the system status page and see 12.1.9. Looks like it is trying to reconnect to the gateway at this point..
- RemyModerator
Jordan,
Remy
